Thread: Radiosity...
Old 06-13-2006, 09:45 AM
halley halley is offline
Well, radiosity is a very compute-intensive way of determining the diffuse-to-diffuse light transport from surface to surface. There's no "real time" way to compute this, and as objects move, any computation would have to be done over. Each polygon in a scene affects every other polygon in a scene, and the effect is proportional to their surface areas. So for a scene with N polygons, you are talking at least N*N complex calculations to determine any extra lighting effects.
To emulate either radiosity in a static scene, or ambient occlusion on each individual object in a scene, the typical approach would be to divide your geometry mesh into smallish polygons, and precompute a UV texture map or a set of vertex colors that can be applied to the mesh during rendering.
This precomputed information is just like a color texture image or vertex colors, except it affects the lighting values on the model instead of the surface color.
I hope that's enough to start googling.
[ e d h a l l e y ]
I'm just a user, not a representative of WorldViz. Hope I've been helpful.
