Thread: PPT error
Old 05-25-2006, 01:29 AM
mspusch mspusch is offline
The way your sytem should be set up is that you have a rendering computer and a PPT computer.
The PPT computer is connected to the rendering computer over a serial crossover cable (Nullmodem cable).
The PPT computer is set (under options) to send data over COM1 (the PPT computer has only one serial port, which is COM1).
The Vizard computer has the serial connection from the PPT computer connecting either to a native serial port (if there is one). For newer computers which do not have a serial port it is connected over a USB to serial dongle (less recommended) or over a PCI - to - serial card (more recommended).
In both cases there is a very good chance that the Port the PPT is connected to is not COM1 on the rendering computer.
In this case, find out what COM port your PPT is connected to (look under Windows device manager - COM ports) and then specify the port of the PPT like this
PORT_PPT = 6 #in case PPT is connected to COM port 6
viz.add('vizppt.dls')
Please make sure that you spell the command
PORT_PPT = 6
exactly the way it is done here (i.e. capital letters) and put the line with this command right in front of the line (viz.add('vizppt.dls') )where PPT is added.
If you use an InertiaCube2 from Intersense with this setup, and it's a serial InertiaCube, then you might also have to find out the COM port for the InertiaCube and specify it. It works the same:
PORT_INTERSENSE = 5 #in case the InertiaCube is connected to COM port 5
