Old 05-08-2006, 11:18 AM
The example code that changes the position of the points uses the actual elapsed time to calculate the new position, so it shouldn't be framerate dependent. Press the F4 key to display the framerate of you simulation in the upper left corner of the window. It should usually be around 60 fps. When you move further back does the framerate drop?
