Old 08-29-2003, 12:00 PM
I tried the model on two different computers and it loaded fine and I was able to move around the scene, change to wireframe mode, and show the framerate. This is the code I used to load the file:
viz.add('Room118d.WRL')
Are you doing anything else, or does it crash just by loading the file as I did above?
You might want to try using the latest version of vizard, 2.10, or you could send me the texture files to see if there is a problem with the texture loader.
