Old 05-03-2006, 06:19 AM
rdotsch rdotsch is offline
I think I figured out a pattern: when I try to change the texture of a mesh, it changes the texture of the mesh that is one step above the target mesh in the vizard resources list. In that list the meshes are sorted in alphabetical order (independent of the order in the .cfg file). Bad luck for me, the mesh I need is the one that is the lowest in alphabetical order, so I can't just use the mesh below it.
I could change the names of the meshes and change them in the cfg file, that's not a big problem. But I'd prefer to use the right names for the meshes, it would make reading the code less of a problem for others.
Kind regards,
Ron
