Child Object Rotation
I am trying to get a child object to rotate about it owns center. The child object is offset in the model and also rotated. When I used the rotate command regardless of Absoute or Relative the object will always rotate about an axis using the offset within the parent.
I tried switching the Parent to World and then I tried to translate back to origin before rotating. This also does not work.
I am not sure what I am doing wrong. Can you please tell me the procedure for rotating a child object about itself.
