What happens if you start out using viz.go() and then go into fullscreen afterwards by pressing F2? Also, does the same machine that exhibits this problem in networked version, not exhibit it in the development version? Or did you test it out on separate machines? The reason I ask is that it might be a coincidence due to the machine not having the correct graphics driver installed.
