Old 04-04-2006, 11:31 AM
In both calls to viz.screentoworld you are adding an offset to the x position. You don't need to do this when using a 3D cursor. Also, after adding the cursor you should disable collisions on it so the bullet does not hit it.
crosshair.disable(viz.COLLISION)
