Old 08-25-2003, 04:36 PM
The windows and viewpoints features was just added to vizard 2.10, so older versions of vizard 2.0x won't be able to run that example.
The main window will always be rendered, even if it is occluded. If you don't plan on using the main window simply set the scene for the main window to an empty scene so there is nothing to be rendered.
