Old 03-14-2006, 10:37 AM
No, there is currently no way for an object to physically move the viewpoint, you would have to calculate this manually.
The best way to simulate a platform would be to create a timer when the user steps on to a platform, and then kill the timer when the user steps off. The code inside the timer would simply perform a relative movement of the view in the direction of the platform. Example:
def StepOnPlatform():
    #Start a timer
def StepOffPlatform():
    #Kill timer
def ontimer(num):
    if num == PLATFORM_TIMER:
        v = platformVelocityVector * viz.elapsed()
        view.translate(v.get(),viz.RELATIVE)
The code above is just an outline. platformVelocityVector should be a vector describing the speed and direction that platform is moving in.
