Old 03-13-2006, 11:15 PM
tobin tobin is offline
Thanks for the clarification. But to press a little further, do you use nVidia's nView Horizontal Span to get the desktop spread across the two monitors or are you using the DualView setting. There is an important albeit subtle difference between the two and you want to be absolutely certain you're using the former.
If you run the gallery world demo that's part of your Vizard installation, do you get this effect with the avatars in that script?
