  #23
Old 03-08-2006, 10:06 AM
The code I posted was made with the latest internal version of Vizard. I realized that it won't work with the version you have. You just need to change the screentoworld command to the following:
bulletvector = viz.screentoworld(pos[0]+0.25,pos[1])
Also, I made this script to show the bullet coming from the mouse. I didn't add any picking to it, so nothing will happen to the avatars when you click them. As I already mentioned, this will only work when you set IPD to 0. However, having an IPD of 0 will make your HMD useless since you won't be receiving stereo images.
