Thread: Object.remove()
Old 03-01-2006, 01:20 PM
I'm still not clear on what you are trying to accomplish. Calling object.remove() will permanently remove the object. Once it is removed you can't use it anymore. If you only plan on having 4 avatars at a time, I suggest you add them all at the beginning of your script. Then instead of removing them permanently, just make them invisible. Then when you want to reuse them later on make them visible again. I would provide sample code if you explained exactly what you want to do.
