Are you only getting this problem when using STEREO, or do you experience it in non-STEREO mode also? Keep in mind that STEREO mode will offset the position of each eye based on the IPD value. However, the screentoworld command returns coordinates based on the point between both eyes. This is probably why the bullets don't seem to be going straight through the crosshair. There is nothing you can really do about this.
