Old 02-27-2006, 02:00 PM
I think it's working out but I do get some traceback errors. Here is the code:
def onmousedown(button):
	global i
		node = viz.pick() #Get object that was clicked
		if node in avatars: #Check if object is one of the avatars
			node.clear(viz.ALL)
			node.clear(viz.CURRENT_ACTION)
			node.execute(7) #Execute the "shot" animation
			#Create action to wait for the animation duration then freeeze the avatar
			WaitThenFreeze = vizact.sequence( vizact.waittime(node.getduration(7)-.14), vizact.speed_node(0))
			#vizact.sequence(vizact.waittime(2),avatars.remove(male),1)
			node.clear(viz.ALL)
			node.add(WaitThenFreeze) #Add the action to the avatar
			node.clear(viz.ALL)
			fadeReset = vizact.sequence(vizact.waittime(1),vizact.call(node.remove))
			node.add(fadeReset)
		i = 2;
Here are the traceback errors. I'm not sure what they all mean.
  File "C:\Program Files\Vizard25\viz.py", line 5916, in mytimer
    curAction.update(elaps,curAction._obj_)
  File "C:\Program Files\Vizard25\vizact.py", line 653, in update
    self.checkaction(object)
  File "C:\Program Files\Vizard25\vizact.py", line 629, in checkaction
    __endAction__(object,self.curAction)
  File "C:\Program Files\Vizard25\vizact.py", line 219, in __endAction__
    object._action.notifyEndAction(action._obj_,action._actiondata_.callbackData,action._pool_)
AttributeError: 'int' object has no attribute 'notifyEndAction'
