The returned object from the
viz.getchild() command should work like any other object.  My guess is that Vizard is not finding the object. To make sure perform the following command after you get the child:
	child = object.getchild()
print 'Child id is',child.id
 If the child id is -1 then vizard failed get the child. Look at the console window for the output, not the interactive window. Let me know if this helps.
