Old 02-09-2006, 02:23 PM
I've attached the plugin you need with small sample script showing how to use it. Keep in mind that this will return ALL named nodes of an object. So you should probably come up with a naming convention to signify which nodes you want to actually retrieve. Let me know if you have any problems.
