Thread: data display
Old 02-07-2006, 05:51 PM
Yes, Vizard should be able to do this through the use of On-The-Fly objects. They allow you to create 3D geometry by specifying each 3D vertex manually. Once the object is created you can modify existing vertices. If you provide more detail of what you are doing I could supply you with a sample script.
