Old 02-06-2006, 02:01 PM
G-Chan G-Chan is offline
using demo with intersense
Currently we have installed in our lab the is900 intersense tracker. I've been downloading the demos (Punch demo) and have been trying to have it work with the intersense system. I first load and send the configuration of our intersense constellation to the tracking system and it shows that it is tracking the devices (we have the cube and the wand), however when I run the demo on vizard I get the following:
File "PunchDemo_IC2_With_FISTHEIGHT.py", line 232 in mytimer
fistPos = data[0:3]
TypeError: Unsubscriptable object
** Error: failed to load plugin intersense.dls
Even when I try the manual demo for the head tracker I get the following:
**Error: Failed to set requested display mode
I suspect I may have skipped a step or need to detect something. Does vizard require some sort of driver for intersense that needs to be separately installed? Any help on this matter would be greatly appreciated. I am also currently using worldviz 2.50, if I upgrade it to 2.53 will I have to pay extra?
Thank you in advance,
George Chan
Sunlab, McMaster University
