Old 09-22-2022, 10:35 AM
apenngrace apenngrace is offline
Yes, I found a solution for that. I'm assuming that you placed a shortcut to the Vizard Cluster Client in your startup folder. Find that shortcut, right click it, select properties. In the properties look for the Run property. Change that to Minimized.
I found that in this article.
