Do you have a callback function that gets called when the mouse is clicked that writes to file? If so, you could disable/enable the callback so the clicks are only registered when you want them to be.
Using Vizard commands, there is not a way to completely disable the mouse. It's possible to hide the cursor or disable mouse navigation. If you search online you may find a way to completely disable the mouse using python.
