Old 10-27-2018, 09:52 PM
The mirrored window on the monitor displays correctly in mono, right? If you run the following code with your vizconnect file, do you see the panel rendered once?
import vizconnect
import vizinfo
vizconnect.go(vizconnect_config_vive.py)
viz.addChild('piazza.osgb')
vizinfo.InfoPanel('Panel Test')
