Old 09-11-2018, 11:59 PM
I'll have to ask a developer if there is a way to get the refresh rate from a connected HMD. You could check to see if the HMD is connected and hardcode the rate based on that.
The following shows how to create create an action from a node3d command:
viz.clearcolor(viz.SLATE)
ball = viz.addChild('basketball.osgb',pos=[0,1.8,3])
light = viz.addLight()
light.intensity(0)
mix = vizact.mix(0.0, 1.0, time=1.0)
change_intensity = vizact.method.intensity(mix)
light.addAction(change_intensity)
