Old 12-19-2005, 12:57 PM
Jerry Jerry is offline
lightmaps with vrml
I found a program that converts Quake bsp files into vrml. It outputs two vrml files, one normal one and the other is the same model but with a lightmap as a texture. Is there some way in Vizard to combine the two vrmls so that the lighting appears the same as in the original bsp?
I have attached the files for you to look at.
