Old 06-17-2018, 04:08 PM
See the notes on the Polhemus page regarding the fastrak connection. In order for Vizard to connect to the sensors, PiMgr should not be running. The following code will print out the data each frame once a connection is made.
polhemus = viz.add('polhemus.dle')
sensor = polhemus.addFastrak()
def printData():
	pos = sensor.getPosition()
	ori = sensor.getEuler()
	print 'pos',pos
	print 'ori',ori
vizact.onupdate(0,printData)
Also, take a look at vizconnect for setting up up a configuration file that connects to the sensor.
