Old 05-27-2018, 11:21 PM
saket saket is offline
Jeff,
I am using the following code to test the effect on my model.
A subset of model with the code file is in attachment. Execute the shader_test.py to see that no effect is applied on the model.
However if I remove "Earth/main_root_L0_X0_Y0" folder then the effect start working.
import viz,vizfx
model=vizfx.addChild('./Earth/main.osgb')
viz.MainView.setPosition(2270347.75*2, 3137376.25*2, 7425973.0*2)
viz.MainView.lookAt([0,0,0])
composer=vizfx.getComposer()
model.generateEffects(composer=composer)
code="""
Effect {
    Float rmin{value 0}
    Float rmax{value 255}
    Float gmin{value 0}
    Float gmax{value 255}
    Float bmin{value 0}
    Float bmax{value 255}
    Shader{
        BEGIN FinalColor
        float r=(vizfx_VertexColor.r-rmin)*255/(rmax-rmin);
        float g=(vizfx_VertexColor.g-gmin)*255/(gmax-gmin);
        float b=(vizfx_VertexColor.b-bmin)*255/(bmax-bmin);
        gl_FragColor.rgb=vec3(r,g,b);
        END
effect=viz.addEffect(code)
model.apply(effect)
model.setUniformFloat('bmin',50)
