Old 05-18-2018, 04:38 PM
Yes, you will need to use the generateEffects command on that model. Here's an example:
import vizfx
import vizcam
import vizshape
viz.setMultiSample(4)
viz.clearcolor(viz.SLATE)
# Disable head light
# Add a directional light pointing down
light = vizfx.addDirectionalLight(euler=(0,90,0), color=[0.2,0.2,0.2])
shape = vizshape.addPyramid(base=(0.4,0.4),height=0.4)
composer = vizfx.getComposer()
shape.generateEffects(composer=composer)
cam = vizcam.PivotNavigate(distance=3.5)
cam.centerNode(shape)
code = '''
Effect {
    Type Highlight
    Shader {
        BEGIN FinalColor
        gl_FragColor.rgb += vec3(0.7, 0.0, 0.0);
        END
effect = viz.addEffect(code)
shape.apply(effect)
