Old 03-14-2018, 06:32 AM
ykykyk ykykyk is offline
Registered User
Questions regarding 3D Sounds
Hello, I am currently using Vizard 4.0 for a school project. (that is the version installed in the lab).
I would like to know what functionality of DirectSound (or which version) is supported in Vizard 4.0. And to be sure, is sound3d.dx.algorithm supported in Vizard 4.0?
When I was searching from the DirectSound API, there are several parameters that wasn't documented from your side.
For instance,
Rolloff factor
https://msdn.microsoft.com/en-us/lib...(v=vs.85).aspx
Or other HRTF related parameters
If I am in the correct version of DirectSound API, can you inform me what "default" parameters are used?
