Old 02-16-2018, 09:45 AM
zmm zmm is offline
Thank you for your reply. I will try out what you suggest for the first point.
For the second point: In my code (see below for the core code), there is not a link to the avatar but selected from the object list, how do I link it to the head if I don't have the tracker?
###server###
import viznet
import steve
import random
viz.clearcolor(.2,.2,.4)
viz.MainWindow.fov(60)
viz.MainView.setPosition([0,1.5,-6])
viz.MainView.setEuler([0,0,0])
objectList = ['vcc_male.cfg','vcc_female.cfg']
maze = viz.add('piazza.osgb')
objects = {}
UPDATE = viznet.id('update')
CLIENT_DISCONNECTED = viznet.id('client_disconnected')
CHAT = viznet.id('chat')
viznet.server.start(port_in=14950,port_out=14951)
def onStartClient(e):
    print '** Client joined with username:',e.username
viz.callback(viznet.CLIENT_CONNECT_EVENT,onStartClient)
def onStopClient(e):
    print '** Client left with username:',e.username
    viznet.server.send(CLIENT_DISCONNECTED,client=e.sender,username=e.username)
    objects[e.username].remove()
    del objects[e.username]
viz.callback(viznet.CLIENT_DISCONNECT_EVENT,onStopClient)
def update(e):
    try:
        objects[e.username].setPosition(e.pos)
        objects[e.username].setEuler(e.ori)
        objects[e.username].state(e.state)
    except KeyError:
        objects[e.username] = viz.add(objectList[e.object],scale=[1,1,1],pos=e.pos,euler=e.ori)
        objects[e.username].tooltip = e.username
viz.callback(UPDATE,update)
###client###
import viznet
import vizinfo
import vizinput
objects = {}
SERVER_NAME='PC04720'
USER_NAME='client1'
while not viznet.client.connect(SERVER_NAME,port_in=14951,port_out=14950,username=USER_NAME):
    if vizinput.ask('Could not connect to ' + SERVER_NAME + ' would you like to try another?'):
        SERVER_NAME=vizinput.input('Enter Server Name')
        viz.quit()
        break
obj_choice=vizinput.choose('Connected. Select your character',objectList)
#set initial position
viz.MainView.setPosition([2, 0 ,0])
viz.MainView.setEuler([270,0,0])
currentState = 1
def sendUpdate():
    ori= viz.MainView.getEuler()
    viznet.client.sendAll(UPDATE,client=viz.getComputerName(),object=obj_choice,pos=pos,ori=ori, state=currentState, username=USER_NAME)
vizact.ontimer(.05,sendUpdate)
def update(e):
    if e.username != USER_NAME:
        try:
        except KeyError:
            objects[e.username].tooltip = e.client
def client_disconnected(e):
viz.callback(CLIENT_DISCONNECTED,client_disconnected)
def onExit():
    viznet.client.disconnect(username=USER_NAME)
viz.callback(viz.EXIT_EVENT,onExit)
def onStopServer(e):
    print 'Disconnected from server'
    viz.quit()
viz.callback(viznet.SERVER_DISCONNECT_EVENT,onStopServer)
