Old 02-15-2018, 09:27 AM
rajnishv rajnishv is offline
Hi saravanan.balak,
You just need to use the below code to switch between viewpoints by loading and removing the appropriate models at runtime.
Beelow is the code for switching between 2 viewpoints but only one single (you can use 2 models and load and remove/unload at runtime and changes the view points.
import vizconnect
import viztask
# start the vizconnect session stored in the given directory
vizconnect.go("vizconnect_config.py")
# oriMode sets what the viewpoint is resetting to. For example...
# vizconnect.VIEWPOINT_MATCH_DISPLAY
# matches orientation of the display to the orientation of the viewpoint
# vizconnect.VIEWPOINT_MATCH_FEET
# matches orientation of the feet to the orientation of the viewpoint
# vizconnect.VIEWPOINT_MATCH_BASE
# matches orientation of the base object (transport, avatar, tracker) to the orientation of the viewpoint
# Similar for posMode
oriMode = vizconnect.VIEWPOINT_MATCH_DISPLAY
posMode = vizconnect.VIEWPOINT_MATCH_FEET
# Add a viewpoint.
vp1 = vizconnect.addViewpoint(	pos=[-13.24803, 12.28260, 8.83578],
								euler=[90, 0, 0],
								posMode=posMode,
								oriMode=oriMode,
								constant=False,
vp2 = vizconnect.addViewpoint(	pos=[-17.24803, 4.28260, 5.83578],
								euler=[90, 0, 0],
								posMode=posMode,
								oriMode=oriMode,
								constant=False,
# Displays are added to viewpoints, the viewpoint will traverse the scenegraph to
# determine if the display is attached to an avatar, tracker, etc in order to
# perform the requested resets.
#vp1.add(vizconnect.getDisplay())
# add an environment
viz.add('piazza.osgb')
display = vizconnect.getDisplay()
def viewTask():
	while True:
		vp1.add(display)
		vizconnect.resetViewpoints()
		print'before 1st waitkeydown '
		yield viztask.waitKeyDown(' ')
		vp1.remove(display)
		vp2.add(display)
		print'before 2nd waitkeydown '
		vp2.remove(display)
viztask.schedule( viewTask() )
Thanx&Regards
Mr.Rajnish Vishwakarma
