Old 01-31-2018, 01:42 AM
ryang1006 ryang1006 is offline
Hi Jeff,
Apologises, I did not make myself clear. I want to change the rotational gain based on the response an individual gives. So that the responses go up and down (like a staircase) in order to find a point at which they cannot notice the gain has been changed.
The problem I am currently having is that the scale euler seems to multiply the gain based on the previous gain value. Is there a way that I can set it back to 'norma'l before I then move to the next value.
For example if I have a gain of [1.3,1,1] and I then want it to be [0.9,1,1] is there a way to get to 0.9 with multiplying 1.3 by 0.9? Ideally, the gain will be [1.3,1,1] then reset to [1,1,1] before [0.9,1,1] is applied. Is this possible?
Thank you!
