Old 01-11-2018, 01:03 AM
A Wundlechner A Wundlechner is offline
Thank you for your reply.
it also opens steamvr when I check for controllers by this command: steamvr.getControllerList()[index]
But it doesn't matter for me anymore, beause in the meantime I already found a solution for my problem. I installed the psutil library. I search with it for the running process "vrmonitor.exe". If I find the process, then steamvr is running.
