Check for running SteamVR
Hello everyone,
for my program I want to use 2 different controlling scemes. One should be controlled with a gamepad and the other one is for steamvr. I want the following behaviour:
If steamvr is already running, I want to use the steamvr controlles.
If it's not running, I want to use the gamepad.
For those 2 cases I've already created 2 configfiles with vizconnect and I changed my specific code parts within the scripts. I only need to know if steamvr is already open.
I haven't found a helpfull command within the steamvr library, to check if steamvr is running. If I run the steamvr.HMD() command when steamvr is closed, it just opens steamvr.
Thanks in advance,
Andreas Wundlechner
