Old 01-04-2018, 02:58 AM
1) if we want to use the vcc_male avatar, how do I figure out what the named key should be for the tracker in line 1 of your code? 'head_tracker' doesn't seem to work.
The tracker name is the name given in the trackers tab of vizconnect.
2) Can you give me a little more detail on the scaling function? I'm assuming that, if the tracker moves x units (let's say in the z-plane), then postScale([1,1,5]) would move the rendered avatar 5x units. Is that true?
Yes, that should work
Also, can the scaling constant be less than zero?
It can be a number between 0 and 1 if you want to reduce the speed.
