Old 01-02-2018, 02:11 AM
rajnishv rajnishv is offline
Hi Vishav,
Through vizconnect you can manipulate the avatar .
Pls visit post to my links by altering teh vizoconnect file:-
http://forum.worldviz.com/showthread.php?t=6044
OR also you can manipulate the avatar sub parts like hand and others using the folowwing examples codes given below.
By getting the handle of Avatar in Vizconnect Config file and apply properties by calling if its available :-
Code 1:-
HTML Code:
avatar = vizconnect.getAvatar('male_2').getRaw()
avatar.state(1)
Code 2:
HTML Code:
avatar.visible(0,'male_head.crfx')
OR for any 3D node
Yes, it is possible to get and set the scale of a vizshape object.
HTML Code:
box = vizshape.addBox() #define box
box.setScale(2,2,2) #change scale by 2x
Lastly u can scale ur avatar thru inspector uniformly or vice versa
OR you will have again export thru 3Ds Max or Maya
Thanx & Regards:-
Mr.Rajnish Vishwakarma
Sr.Software Developer
Mobile Application,AR,VR,Amazon WebServices.
