Sorry, I don't have a solution here. I've seen the same issue reported before and it seems related to the combination of GPU/drivers. What is the graphics card you're using? Have you tested the same code on other machines? The only suggestion I have is to roll back and try out several different driver versions. Other than that, use vizinfo panel or a 3rd party GUI library (e.g. Tkinter) to create the GUI in Vizard.
