Old 11-08-2017, 07:20 AM
It's not possible to modify the vizinput dialogs but you could try using vizdlg components instead. With vizdlg, the button labels can be changed. Here's an example:
import vizdlg
import viztask
# Function to validate value entered in InputDialog
def checkLength(data):
    if len(data.value) != 6:
        data.error = 'Incorrect length, try again'
        return False
        return True
# Create an InputDialog object and position it on the screen
dialog = vizdlg.InputDialog(prompt='Enter a value with 6 characters', validate=checkLength, accept='Next', cancel=None)
dialog.setScreenAlignment(viz.ALIGN_CENTER)
def showdialog():
    while True:
        dialog.value = ''
        yield dialog.show()
        if dialog.accepted:
            print 'accepted',dialog.value
            print 'cancelled'
        yield viztask.waitTime(1)
viztask.schedule(showdialog())
