Old 05-25-2017, 06:00 AM
bbb bbb is offline
Hi Jeff,
I upgraded to the latest version of vizard (5.7) but i steel have the same problem. I can't change the default setting since i receive an error :
File "C:\Program Files\WorldViz\Vizard5\python\vizact.py", line 3013, in __onevent
ret = e.call(val[1])
File "C:\Program Files\WorldViz\Vizard5\python\vizact.py", line 2948, in _callStatic
return func(arg,*args,**kwargs)
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\interface .py", line 1286, in <lambda>
onMessage('Vizconnect.Node.commitChanges', lambda e: self.commitChanges(e.data.classification))
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\interface .py", line 491, in commitChanges
self._getEditor(classification).commit()
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\edit.py", line 287, in commit
self._removeLive()
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\edit.py", line 809, in _removeLive
self._updateNodeCode(name)
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\edit.py", line 1115, in _updateNodeCode
code = self._parser.generateNode(name, data)
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\code.py", line 1725, in generateNode
code += _trimdentN(self._generateNodeMappings(data, target='raw'), 1)
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\code.py", line 1172, in _generateNodeMappings
code += self._generateNodeMappingsPerFrame(data, target)
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\code.py", line 1228, in _generateNodeMappingsPerFrame
mapping.generateMagCode()
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\code.py", line 269, in generateMagCode
signalMagCode = templateObject.getMagnitudeCode(signal['inputName'], signal['signalName'])
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\template\ input.py", line 108, in getMagnitudeCode
raise ValueError()
ValueError
I can change the input signal but walking right and left
(not turn right or left) relates to the keyboard since it stays as been programmed the first time (like your company developed, in the preset mode).
