Old 05-24-2017, 04:01 AM
bbb bbb is offline
Hi Jeff,
it seems to work the way you suggested but i now have a different problem because in order to move forward, backward, left and right i must use the keyboard but i need the xbox controller buttons to do so (Y,A,X,B) since participants need to navigate and can't see the keyboard. If i'm trying to change the mapping such that the controller buttons will be used for walking, it's not moving and steel refers to the keyboard ( as the way to walk. I also want to separate between walking (controller buttons) and orientation (turns with the left stick) because i want from the participants to just turn around ( without the possibility to walk) when getting to a target zone in order to learn this place and return to it in the next try.
Thanks.
