Old 11-15-2005, 05:11 PM
Adam Adam is offline
We are using an intersense inertiacube2 to handle orientation tracking and the ppt to handle position tracking.
We have had trouble automatically applying the data from these to the viewpoint with the viz.tracker command so we are mannually applying the data to the main viewpoint with a continuously running timer that applies all tracker data with translation and rotation commands.
Your last post suggests that it is the intersense that is passing the troublesome values to the viewpoint.
I'm not sure what I can do to avoid this issue if we are feeding the viewpoint raw data from the tracker.
Any suggestions?
