04-26-2017, 12:57 AM
Try the following:
- Run the cluster master, enable local host with count of 1. You should have two application windows when running vizard or vizconnect.
- In vizconnect, add the custom window display for the monitor and leave subWindow enabled
- Press the visibility window for the custom window, set monitor(s) to fullscreen on, and set to visible only on client 1
- Create a group tracker in the trackers tab, press the Offsets button for the tracker, and give it a position by setting the postTrans values
- Parent the custom window to the group tracker. The custom window viewpoint will be set to the position of the group tracker
