This is usually caused by having an invalid rotation on a node or viewpoint. An invalid rotation is most likely caused by an axis length of 0 when using a Axis-Angle or Quaternion rotation. Make sure this isn't the case. Also, are you using any sensors that pass back rotation values? These might be the cause of the invalid rotation.
