Old 03-06-2017, 06:20 AM
zumbay zumbay is offline
Execute function at high sampling rate
I have an input device which can sample at a higher rate then the refresh rate of my monitor. What is the best way to save the data from that device?
Will calling a function which saves the data (e.g. using sensor.getData()) with vizact.ontimer(0.004, savedata) yield an accurate result? And how will it behave when the scene is rendered?
Thanks!
