Old 01-25-2017, 02:04 PM
Canucks Canucks is offline
Treadmill , Optotrak & Vizard
We are trying to run Vizard for Optotrak in which the participant walk on the treadmill. The problem is since it's on a treadmill, on Vizard it shows it as going back & forth ( not moving forward) since the coordinates are not changing ( ir: you go from (0,0,1) to (0,0,2) even if you go 10K on treadmill). Is there way to fix this issue?
