Old 01-23-2017, 12:45 PM
Reducing the bounce of the box may help prevent it from falling over after it's dropped. Here's an example:
Press spacebar to enable physics and drop the box
import vizshape
import vizinfo
vizinfo.InfoPanel()
viz.clearcolor(viz.SLATE)
ground = viz.add('ground.osgb')
ground.collidePlane()
box = vizshape.addBox(size=(.4,2,0.4),pos=[0,20,8])
shape = box.collideBox()
shape.setBounce(0.01)
vizact.onkeydown(' ',viz.phys.enable)
If you want objects to snap into place after colliding try handling the collision event and then animate or directly place the object where you want it to go.
