Old 11-03-2005, 09:17 AM
There is an internal limit in Vizard on how big a message it can receive over the network. Currently the size is 4096 bytes. The pickle string is probably exceeding this size.
This is an unusually large size to be sending over the network. Are you sending these messages every frame? If possible, try to cut down the size of the message to only the relevant data. If you still need to send this much data then let me know and I will provide you with a work around.
