Old 01-12-2017, 12:19 AM
zytcll zytcll is offline
Physics engine problem
I have a long bar with nodes from [node00] to [node10] side by side, and its center is as same as [node05].
Now I want to let parts of nodes visible and fall down, so I set collideBox to only these nodes, and set other nodes with collideNone.
When center node [node05] is included in collision nodes, it works normally. However, when center node is node included, it starts rotating after landing.
bar.setPosition([0, 4, 0] )
for i in range(11):
	nodeName = "bar"
	if k < 10:
		nodeName  += str(0)
	nodeName  += str(k)
	if (k > 6) and (k < 9):
		bar.visible(viz.ON, node = nodeName  )
		bar.collideBox(node = nodeName)
		bar.visible(viz.OFF, node = nodeName)
I think I should reset the center of the bar, but it still works badly after I use setCenter(pos), so is there any way to solve this problem?
