Old 01-07-2017, 07:10 PM
sagar29 sagar29 is offline
I am trying to send data as packets of doubles in little endian format from MATLAB(Simulink) to Vizard. Since MATLAB is non-python interface, I am using code give on the forum and it is:
from __future__ import print_function
import socket
log=open("new.txt","w")
print("Hi there",file=log)
#The maximum amount of data to receive at a time
MAX_DATA_SIZE = 1024
#The port to send/receive data on
PORT = 5600
#Get the name of this computer
COMPUTER_NAME = socket.gethostname()
#Get the IP address of this computer
COMPUTER_IP_ADDRESS = socket.gethostbyname('localhost')
#Create a socket to send data over
#OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
#OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
#Create a socket to receive data from
InSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
InSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
InSocket.bind(('192.168.1.2', PORT))
InSocket.setblocking(0)
#def SendData(data):
#OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT))
def ReceiveData():
try:
return InSocket.recv(MAX_DATA_SIZE)
except socket.error:
#Insert error handling code here
print("Error has occured",file=log)
#vizact.onkeydown(' ',SendData,'hello there')
def CheckSocket():
#Try to receive data from socket
data = ReceiveData()
if data:
print (data,file=log)
print("Data not received",file=log)
vizact.ontimer(0,CheckSocket)
I have removed data sending part by making it comment and trying to get data in file so that I can analyse(One more reason is that when I write simple print, I am getting nothing in Vizard). I am not understanding second line in socket creation for receiving data and also not getting any output.
I tried to send data from MATLAB to MATLAB and its working but with Vizard it is giving problem.
Please suggest appropriate corrections in code.
