Thank you for this option; I have thought about it, but the problem is I'm stuck to Delphi for the user interface.
You don't know a way to make the remainder of the 'main' viewport invisible, i.e.: in fact you just see the two separate viewports?
There will be a solution with Delphi combined with CoolForm, but that proved to be too buggy to use in a real application.
Thanks for thinking about the problem!
