Old 11-18-2016, 03:45 PM
You're right, the highlight object is not defined in the RayGrabber class. I've attached an example that uses a modified version of grabber.py so it works. By default the placement mode is point and place so the object will snap to a surface when released. The placement mode can be set to something else, such as mid-air placement, in the RayGrabber code.
